Hi everyone
I have XZ and i download the last update for my phone, but unfortunately the network signal is interrupting between time to time.
Please help me solve this issue.
Thanks
Ok thanks
The number for signal strength
-67 dbm 23 asu
@9901110: have you observe if which network type this low signal is?
it will switch to the next network preffered type if can't get a good signal of the previous type. example, if in your area you have weak 4g signal but strong 3g signal, and your settings is 4G preffered, it'll have 1 bar of 4g signal instead of having full bar of 3g signal.
