wallpaper issue
Not applicable
wallpaper issue
Hi
I am having trouble setting up wallpapers as I wanted. First, I downloaded a bunch of 320 x 480 px jpgs, as this is the screen resolution. Moved them to the phone, but when I try to set the wallpaper, I have to crop the image to a much smaller size! The result is:
1. only a small part of the image is used, anyone knows the resolution?
2. the pic is spread over the three main screens (or whatever are called, dont remember), so you cant see even the small part of the image you selected the whole time, you only see the rest when you move to other screens.
Is there a way to have only a single 320 x 480 pic as the wallpaper all the time, in all screens??? This makes no sense to me.
thanks
1 REPLY 1
Er_Kannan
Contributor
Use images of resolution 480px x 320px
You can use an application named Zedge available on market that can help you in setting wallpapers and you can find many good wallpapers using this application.
