W960i USB Connection Problem.
Not applicable
I am running PC Suite 1.6.0 on a Windows 7 Ultimate PC. I can connect my W960i to the PC in 'Fast File Transfer' mode no preblem. However, I cannot connect in 'Phone Mode' to the PC Suite or in Bluetooth. I am trying to keep my phone sync'd with Outlook 2010 calendar and contacts.
I have tried rebooting the PC without disconnecting the phone, re-installing the PC Suite, re-installing the PC suite with McAfee disabled, changing 'Compatability' settings in Windows 7 for the PC Suite to XP Service Pack 2 and Service Pack 3. Tried a 'Master Reset' and I have confirmed I have the lastest Software Version on the handset.
I have run out of ideas now. Can anyone help? :smileygrin:
Thanks in advance.
5 REPLIES 5
Dr_Chris
Champion
You can try re-installing the phone's software via the SE update application on your PC.
Not applicable
Will try that now.
Will post again shortly with results. :smileygrin:
Not applicable
Same result. Phone connects fine in 'File Transfer' but will charge only in 'Phone' mode.
I noticed during first connection in 'Phone' mode a Windows balloon notifying searching for drivers, this failed with 'Device disconnected' message. Still stuck. Crying_Face
Dr_Chris
Champion
Not applicable
Dr_Chris,
               OK. No hub. Tried a restart with phone connected. Check device manager, COM 11 is Sony Ericsson PC-Connect Port and COM 19 is Sony Ericsson W960 Application Port. No other phone or PDA Software installed and tried a clean install with McAfee disabled. Spyware scan came back clear. Unfortunately I'm a carer for 2 disabled kids and a single Dad so live on benefits and don't have the option of another PC to try.
Any other ideas?
