w395 bluetooth not functioning
Not applicable
hello, i own a w395 walkman phone. when i starts a bluetooth it shows meessege "canceled"
and bluetooth never gets start. it also creates a dump files in memorycard each of 16 mb in size.
i repair it for three times from service centre, two times they changed the motherboard of it, but after 7-8 days the bluetooth not fuctioning.
please help me...
thanks
3 REPLIES 3
Dr_Chris
Champion
I used to have the W395 and it would also create these dump files, usually when downloading emails, so I just had to delete them because they took up too much memory.As for your Bluetooth problems, you could try a master reset, as this is the only reset option for this phone.Hope this helps.
Not applicable
how to master reset the w395?
please tell me..
i reset it many times by resetall option located in
Menu--->Settings---->General------->ResetAll
but nothing is happen.
thanks for reply...
Dr_Chris
Champion
You have to select the Reset All option and the phone will reset itself and then restart itself--if it doesn't and it gets stuck on the SE logo after the reset, take the battery out, replace it and restart it.
