Hey all - I'm totally new with Xperia 8 and with touch screens also - so be nice.. How do I delete a voicemail when I cannot press the number as told??
HAI,
ACTUALLY UR QUESTION WAS NOT CLEAR,
ACCORDING TO THAT I THOUGHT U ARE TRYING TO DELETE UR VOICEMAIL NUMBER......
HERE...
GO TO SETTINGS------->CALL STEEINGS------>VOICEMAIL NUMBER------>
HERE TO DELETE THE VOICE MAIL NO...
TAP ON THE NUMBER THAT YOU FOUND IN "VOICEMAIL" IN "CALL SETTINGS" AS SAID ABOVE ....THEN U'LL FIND THE KEYBOARD ON UR SCREEN...USE THE DELETE KEY(marked with 'X' symbol) TO DELETE THE VOICEMAIL NUMBER AND TAP ON 'Ok'..THEN UR VOICEMAIL NUMBER WILL BE REMOVED.
Thank you - but what I mean is not how to change the telephone number to the voicemail service - but how to delete the actual message delivered. When I check my voicemail it says " to delete this message - press 3" - how do I do that?
You'll likely see a message to 'Tap Twice' to use the screen again. Then at the bottom of the screen you'll see a little tab you can drag up to see your numbers again. Did that work for you?
