Hi All,
To keep this simple, I would like to turn off my vibration setting for my text messages when my phone is in normal mode.
But when I turn my phone to vibrate mode, it doesn't vibrate at all. Is there any way I could have this setting off in normal, but for it to still vibrate when its in vibrate mode?
Hopefully that makes sense.
Thanks in advanced!
Hi @ThundercatX,
Welcome to the community.
In the default system this is not possible, but you could download a third party messaging app from the Google Play Store that has this functionality.
Hello there!
Thank you for the warm welcome!
I thought so, I just wanted to make sure.
Could you make any suggestions for any apps?
I'm not very tech savy.
Thanks again!!
As Cameron suggested Google Play Store is your choice here, there are a miriad of Apps & my advice & tho time consuming is to just carefully read thru the descriptions of each & download/try them out.....if it does not have the function you require simply uninstall it....have a read of the customer reviews & look at how many downloads each one has had, this is a good indication of how good it is.
