do you experience this while you are in safe mode?
try to run diagnostics ,, settings>about phone>diagnostics, does the display work well?
@Colborne93 wrote:
Hi, I woke this morning to find that my home button and recent button aren't working and the notification bar is not displaying notifications.
It started after turning it on after a full charge over night after it ran out of battery. I originally thought it would be nova launcher, I changed to xperia home and its still doing the same. I attempted to create a manual backup so I could restore but for some reason the backup isn't working, so i would rather find a fix first before going for a reset.
Touch screen itself is fine, the back, home and recent buttons vibrate after I've disabled the vibrate and the touch screen diagnostic is fine.
Touchscreen works but not the back/home buttons? Have you tried diagnostics?
Pretty much tells me it's partly a touchscreen problem.
