ok this is probably not the right place but i have spent the last few hours trying to find themes for the satio and every site i go on either says use nokia 5800 themes they work fine or search s60 themes . well i have done that and 5800 themes are awful to say the least and so are the s60 themes , are there not any themes available that are souly dedicated to the satio , i really hate all the 5800 n s60 ones they all look so bad
how about using Sony Ericsson Themes Creator? with the help of it you'll create a theme that'll fully meet your requirements
Here is a link to Sony Ericsson themes creator which will be able to make a personalised theme. http://www.sonyericsson.com/themescreator/main.aspx?cc=gb&lc=en
thanks i actually downloaded that yesterday to have a go , but i couldnt get the hang of it nor could i change the size from 240x400 to 360x640
in the top right side of the window you just change the model you want to create theme for
yeah thanks i found that . i used the creator but its real poor just like my satio
Themes creator is good if you use your imagination.
and Photoshop or Gimp. they'll allow you to create custom wallpapers and highlights... it's worth trying
i'm still wondering how come you can't export the themes to your phone? i'm having problems with doing that with my crappy vivaz 😐 can anyone suggest anything?
