Hello I have problems with the keyboard of my experia XA. I am getting very frustrated with it, please help. Since yesterday when I press the keyboard twice, the screen gets bigger, an orange border appears and it goes crazy 😵
You have enabled talkback mode for blind people. To disable it, use two fingers to move around and double tap to select an option or to confirm.
Talkback can be found under settings - accesibility.
