hi there i don't know if some one can help me but everytime i open up any txt message its blank or it will say "corupt message" so i have no idea what people are saying to me if someone could get back to me that would be much apriciated
thanks
x
Run the update service on your phone.
I had the same probem with my phone but its easy to fix make shore all your files are saved on a memory card and number then go into settings then profiles then all the way at the bottom it says master reset cick that then reset all problem solved
