Hey guys!
I recently got a Sony Ericsson Spiro with the included Headphones, but they are the sort which don't get on with my ears. I have some old headphones like THESE ONES but they are a different connection type.
http://www.hardwarezone.com.my/img/data/nnews/2007/6577/File/earphones_l.jpg
The only way I can get those (above) headphones to work is if I unplug them halfway and put the single plug in my Spiro which is the only way I can connect them, which leaves the wires too short like this...
http://www.itechnews.net/wp-content/uploads/2008/02/sony-nwz-a720-series-walkman.jpg
So basically are there any headphones out there which I can get a long cable for (more than a few cm's like the above link
) which have a single cable connecter (like the above link) for my Spiro? They also have to be like these... (the soft type, not the hard type)...
http://regmedia.co.uk/2008/10/29/se_is800_2.jpg
Thanks and please help!
Dan
Hi Dan
I don't know if you've managed to pick up a set of headphones yet but if you haven't, have a look at iLuv1353 or Sony MDR-ED21LP.
I have a set of the Sony ones.I got them as a present and thought I wouldn't like them but they are good.I've got rather small ears and the usual Fontopia style keep falling out but these ones are rubber tipped and they fit well.The only down side is that they don't have an in-line volume control which means that you would have to reach for your player anytime you want to adjust the volume but there are a lot of other (more expensive!) Sony ones available with the on-line volume.
Reviews for the headphones mentioned above can be found at:
http://www.argos.co.uk/static/Product/partNumber/5342196/Trail/searchtext%3EHEADPHONES.htm
I hope you find this useful.
David
