SE W810 camera problem
Not applicable
I had not used my phone camera for about a month and when I later used again there is an error. When I open the camera through the menu, shortcut, everything, it just shows the camera screen for about a second and then disappears again. How can I solve this problem?
3 REPLIES 3
Dr_Chris
Champion
Run the SE Update service on it and see if that restores the camera.
Not applicable
there is a connection between the screen and the camera which might have bcome loose....just remove the housing once and check..My brother had the same problem in his W810i also.....check n tell
Not applicable
It happened to me a lot when used to have that phone. All I did was restart the phone and it was working again. But yeah you should try opening the phone, maybe it's the connection.
