USING SBH 80 PAIRED WITH XPERIA T. "To view the estimated battery time. Find and tap Settings > Power management > Accessory". NO ACCESSORY HEADING. WHATS UP WITH THAT?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Try using Smart Connect instead. Open up Smart Connect > Devices > SBH80 and you should be able to see the remaining battery time.
I've got a SBH80 Bluetooth headset, but the wires buds got a loose connection, intermittent sound when you move it. Can I change the wire, repair them, or anything. I really like them.
I guess you need to contact the Sony support to be able to send it for repair mate.
