Hello,
I have my Sony Xperia M4 Aqua Dual (Android 6.0.1 / Build 26.3.B.1.33) since a year and I have never encountered a problem until then.
But for a few days, I have a problem with my microphone.
I explain my problem, when I pass or receive a call, my correspondent doesn't hear me.
If a active the loud speaker, then my correspondent hear me but just after, if I disable it, my correspondent doesn't hear me once again.
The problem is just with the microphone of the phone because when I connect my handsfree kit, no problem.
I searched on the internet for similar problem and I see that is current problem.
So, I tried many solutions like :
But nothing has changed after trying the above solutions.
Do you have a solution that worked for you?
Unless the only solution is to return the phone for repair but it bothers me because it doesn't seem to be a hardware issue...
Hi everyone.
A few days ago I was update from 5.0 to 6.0.1 android firmware, but since update I have problems with microphone. When I take both incoming or outcoming calls started, people cannot hear me.
I reset to a factory settings directly by the phone and using Sony Xperia Companion but problem still remains.
Also, I´ve been performed test diagnostics and safe mode and the result is that it cannot pass the test.
I´ve just canceling supression noise and clear audio settings, but microphone starts to operate as well for a couple of minutes, then mute again.
This isuse begun since update my phone to 6.0.1.
Does anybody has this issue too? Any solving for this?
Thanks in advance.
