Problem with Application updates
nkkapasi
Visitor
Since the last few days the Google Android Marketplace shows that there are updates available for a few of the applications that I have installed. But when I try to install them it says the download is unsuccessful. My connection to the internet is pretty good and I am able to browse, mail and chat, but the application updates seem to have some problem.
Today I tried installing a new application and faced the same problem. Anyone else faced this problem? Any idea whether this is a instrument or mobile network or Android Marketplace issue?
I use the XPERIA X10 Mini Pro with 1.6
5 REPLIES 5
Not applicable
I have the exactly same problem. Dont know if I should try and update the sw even though I read about some problems coming with that or just wait for the new Android version thats coming soon and hope that it will solve this problem.
Not applicable
From http://www.google.com/support/forum/p/android/thread?tid=6e05c454ac2e5c2c&hl=en:
'Go to Settings -> Applications -> Manage Applications
Go to the "All" tab and select "Market"
Click "Clear data" this will reset the market app and fix the problem.'
HTH. YMMV.
Not applicable
Didnt help...... Slightly_frowning_Face
Not applicable
Try this it just fixed mine
The problem is caused to an update of Android Market. To overcome this,  go to Settings> Application> Manage Applications & find  Android Market from the list. Select Android Market and click Uninstall  Update.
Not applicable
Thank you!!! That worked Winking_Face
