I bought a SE Xperia X8 2days back.....My phone was restarting continously....
I played a Video in it then it was getting restated. I brought it to sevice centre..they Updated th software of the phone....eventhough My XPERIA X8 was getiing restarted while playing video.....can anybody..help me Pls
The only thing I can suggest is that you try a repair / reset via Sony Ericsson Update Service. This will factory reset your phone and wipe everything and reinstall the software. Please ensure that you have backed your contacts up to your SD card or synced them with google so you don't lose them.
If this doesn't work then return it to where you bought it from for a replacment.
return it for replacement. Mine has no issue
