I had mine X10i over 4 months now, no matter how I updated the version or reset the device back to factory default, the WiFi still did not work properly unless I re-start the device. The WiFi only can be turn on is when the device just turned on. If the WiFi connection got disconnected or was being turned off, then it can NEVER be connect it back or NEVER can be turn back on. This is killing me:smileycry: that I have to at least re-start my phone twice a day. Another thing is that if I don't turn on my WiFi at the time the device was turned on, then I never could be able to turn on the WiFi again. What is the issue with this function? Can anyone help me please!!!
I had same prob. so I called the ppl that made the wifi device, I had to reset the wifi device & that fixed my prob. with X10
Thanks for the reply, so do u suggest that I should bring the device out to those fix cellphone place for reset the WiFi? cuz I don't know if they are trustable. I'm in Los Angeles, CA.
