Hi
Is it possble to buy body (front and back portion) of W350i mobile phone.
It is not under warrenty... I am ready to pay I jsut want to be able to use the mobile again.
Thank you
Sam
If you take a look here http://cnn.cn/shop/sonyericsson-w350i-c-28_599.html you will find some housings for yoiur w350.
Take the phone to your dealer and see what they have to say. In normal case you should get a new case. Try to take the phone to an Authorized dealer for better results and genuine parts.
Thank you, let me try it
Thank you for the response but the autherised dealer kept my phone with them 4 weeks, never responded positively, when I asked for update and in the end said it is not available.
I never felt they where keen to order it for me... may too small a business for them!
