Is there a PDF viewer that I can install on my X10 mini pro? I can only find 3rd party apps on the marketplace and know that friends with htc android phones get a PDF viewer with the phone.
You need a 3ed party application.
Any recommendations?
I use Documents to go.
Use the office suite. For more information see the blog entry by SE http://blogs.sonyericsson.com/products/2010/08/20/opening-attachements-on-the-minis/
There are PDF viewers that
1) let a server on the internet do the work (rendering), therefore require internet access;
2) let the phone do the work (rendering).
1) will normally be able to handle more complex PDF documents, for which 2) possibly fails.
For 1) the speed depends clearly on your internet connection.
I use Android PDF Viewer (which is category 2 and was free on my market), and it has worked for me so far.
