I have a big problem,it happens once a day(it happend before MR1,with MR1,and with MR2). Cant unlock the screen,when I need to drag padlock left or right it just cant,padlock stays on the left or right side, I can get it back to the middle but unlock - NO (sometimes it promts for some ''unlock code'' but it is not usual lock code as I never set a lock code) and in mean while if you receive a call from some one he complained later on that why didn't you receive the phone, my answer is always that phone never vibrate or ring but when i check the miss call log the call was really there.
The only temporary solution is soft reset. Somebody have something to say???
Hi Future_President,
that is one of the known problems of the X2. Happens rather often with the never specified "unlock code", when the battery is in the lower third. Try to prevent it by loading it more often. In the last months I had the battery level of my X2 nearly always in the upper half and it did appear only one or two times again.
Second, try not to open too many programs in parallel. I also have the impression that the case without "unlock code" happens more frequently if too many programs run at the same time and/or there is not much free memory left. So either you should soft reset the device regularly (I do it about every 2 to 3 days) or use at least the task manager to kill some programs from time to time.
Third, ask SE for the next update to cure these problems. The more people ask, the better is our chance that they provide another stability update 😉
so how can i lock the phone ?
problem is when i lock it ,after 1hrs i cant unlock the phone !!
