Hi
Got an mini pro back in August had terrible signal issues with it, not able to make calls or use net. Had a replacement delivered two weeks ago and still havging signal issues. Also I have to make 3 or 4 attempts to call one person, it either shows the caller screen for about 20 seconds doesnt connect then goes back to call history, or just beeps and goes back to call history. On the last attempt it usually takes about 20-30 seconds before i hear the ring tone. Is this the phone or my contract provider? Any ideas? Wil the new software update help me? Is it available in UK now? i am not loving the phone, it is slow and doesnt do anything is says it's meant to at the moment!
Try contacting your network provider for help, and make sure you have minimum required signal strength to make a call. Such an issue is not the problem of the phone alone, it can be a network trouble also. Try using a different provider if it is active on other networks just to test if u have the same problem. Also try making calls when at a different location (away from the one you are currently facing the problems). If you still see the same problem, please elaborate what you are facing.
NOTE: Sometimes mobile BTS's (Cell phone towers) can range over a circumference of 1-5km's so please check outside this radius (ie. outside the particular location u are facing problems).
