K770i Camera Problem
Not applicable
when open my K770i camera "lens cover" the camera work but every few seconds or minutes return automatic to phone desktop then return alone to camera without press any key.
knowing that the problem is new one and i remove the memory card & check it, it give the same problem.
6 REPLIES 6
KrazyD
Contributor
Try updating the phone using Sony Ericsson Update Service and remember to backup your files etc as this will be erased during the update.
Not applicable
i try update using Sony Ericsson Update Service but it give me that my update is the latest update knowing that i don't update it before.
KrazyD
Contributor
Ok well download se pc suite and try the repair option which will do basically the same thing.
Not applicable
ok
iam not in home right now when i return i will try & reply, thanks
Not applicable
i download se pc suite 6 and make repair to the phone but still the same problem
Markus1
Leader
Hi billoo,
I'm sorry hear about your issues with your K770i.
If you cannot perform a update and the repair does not help I suggest you contact your retailer to have your phone sent to a repair center.
