Hi, I have the most weird problem with my set. I have enabled talkback and then the phone got permanently locked. I cannot swipe and unlock. The phone keeps saying like a robot staff that I do not want to hear.
Does it happen with any Xperia J or I am the exception? Can you please guide me how to disable the talkback feature.
Thanks
really thank u!!!!!!!!!!!!!!!
man!!!!!!!!!!!!!!
how can i thank you?????!!!!
it was reallly helpful!!!!!
thank you a lot!!!!!!!!
THANK U SO MUCH BUDDY......
i t took me a while but after much frustration I got it.
finger & thumb as far apart as the screen will allow double hit your screen then pinch your finger & thumb towards each other like you would to reduce the size of a photo, your home screen will then be there, but it doesnt end there, you thenn have to double hit settings, thenn double hit the bottom icon then scroll the bottom icon up & repeat until you see accessibility, double hit that then double hit the talkback on/off switch. job done
Thanks a lot. got caught upin this mess and was able to get out thanks to your imput.
