I just bought my XA1 this week, everything is running smoothly, the only issue is it overheats, I'm just using my facebook and no other applications opened, sometimes i play clash of clans but after playing i always ensure that it is closed, i just want to know if this is a issue or it is normal? In facebook sometimes i watch videos but on an average of 8mins only. I hope someone helps me, thanks
Even when you close an app, some will continue running in the background, facebook it is known to be a heavy battery hog app, it will drain your battery faster and heat up the phone; the phone can't overheat, as if it gets too hot, it will shutdown to prevent any damage.
Thanks for the reply, i have one question, is it normal to heat up while charging even though it's turned off?
Yeah, but it shouldn't heat up a lot, unless it's a really hot day it might have an effect, which wallcharger are you using?
It's heating up like I'm playing some games, im using the original charger of my xa1
