AS THIS MOBILE HAVE SNAPDRAGON 615 CHIPSET , I THINK THIS MOBILE HAVE HEATING ISSUE
AS ALL THE MOBILE LAUNCHED HAVING SNAPDRAGON 615 CHIPSET HAVE HEATING ISSUE , EVEN AFTER 10 MIN.. OF CONTINUES BROWSING THE HEATING ISSUE EXISTS
EVEN THE XIAOMI MI4i LAUNCHED WITH 2ND GENERATION SNAPDRAGON 615 CHIPSET STILL HAVE SAME ISSUE
SO HOPE SONY WILL SOLVE THIS ISSUE SO THAT USER CAN USE HANDSET WITHOUT ANY PROBLEM
AND CAN ANYONE PLEASE TELL THAT EXACT RELEASE DATE THERE IS NO HELP WITH XPERIA CUSTOMER SUPPORT FOR THE RELEASE DATE
Heating is dependant on what you are doing like taking videos or watching youtube and playing games
Hi @Devrante
I suggest install an app like Cool Master https://play.google.com/store/apps/details?id=com.precinct.coolmaster&hl=es_419 to monitors and logs device temperature in real time, and displays temperature change curves. So you can post those values here to be able to analyze them.
I'm at disposal for any question.
Best Regards,
Sony has released an Update, I got it yesterday, its some 355 mb.
It has solved heating problem to a great extent. On opening camera it does not heat at all as it used to.
Also while playing heavy games it does heat but not as bad as it used to. So you cannot fry an egg on it :(,
Thanks Sony for fixing the issue.
removed add from OLX...psst
From what I know the update is available for the M4 Aqua Dual - does anyone know if there's an update ready for the standard model?
Hi @electronique
You can check this link:
Which version of Android is your device running now?
To find your device’s current software version:
Settings > About phone > Build number / version
Best Regards,
I Jeff...I bought new Xperia mobile ph M4 aqua...my experience is harrowing...all.I do is keep my ph charging thru the day n it discharges as if flood gates open up monent I put the ph on data network..either wifi or GSM...the other issue is very high level of heating of the phone while charging or talking or browsing...I didnt expect such poor quality junk from Sony...I even showed it to the dealer frm whom I bought this device..but didnt get satisfactory response...I am very unhappy with this ph and hv already discouraged many frnds frm buying it...
Dear Sony Team
I bough a M4 for my wife in replacement of an old Xperia T middle of July and she complain also about overheating issue. I also having be able to experince it myself. After having use the phone, and disable the screen, sometimes the phone still overheat itself witout using it and recovering for this condition is only possible using the small reset button next to the SD card.
I am extremly disappointed about this issue, because it is a blocking one. As I see in this forum, lost of uses complain about overheating issue and this is not acceptable.
This phone cannot be recommended to anyone because the price I not only the criteria. There is lots of other manufacturer making great middle range phones but Sony is going to loos customers if quality is not provieded.
In fact I do not want to loos time in proving agains Sony Support that this phone is rubbish but will throw it away and bought a Motorola Moto X instead.
Please do not hesitate to forward my statement to your product managment in order that they will know what customer are thinking.
I can only encourage you to improve your product quality.
An ex- Sony customer.
