Since firmware 32.2.A.0.224, which I just got via OTA there is a permanent notification that tells me that my headset is connected, when my headset is connected (surprise).
I cannot swipe it away and I also cannot permanently hide it by long-pressing and clicking (i), since there is no option to block all notifications from this particular app.
It would be great if this notification could be made optional, or even removed since it's quite useless and a huge waste of notification space.
Also my vote for removing this notification (completely useless otherwise). I don't get it, why change the behaviour of the Z5 after almost one year? Is it simply to annoy current users?
IMO, Sony should concentrate on fix current bugs.
After the latest update I get a notification Headset is plugged in and an Icon.
On the lock screen notofication Phone Call Management shows up.
Can I get rid of it?
Thanks.
@Bearings wrote:
I suggest those with suggestions on design issues please join beta testing on Google+. You get to help Sony enhance their app or UI better instead of raising it here in a user forum.
If you're talking about https://plus.google.com/101664517498434307972 it's opened to Z2 and Z3 users only.
This only started this past week and I've had my Z5 Compact for several months, so I'm assuming this came with some update or other. This notification is coming from "Phone Call Management" (an 'app' with the same icon as the built-in default dialer app). The notification itself is useless because, if I'm holding my phone to see the notification, I can also see whether or not headphones are plugged in. The notification tray is for important things that I plan on using somehow, and I don't usually have room for extra ones; it clutters up my view of what's happening on my phone and obscures much more important notifications. Unfortunately, I can neither disable the 'app' nor turn off its notifications. Developers: could you please make this setting optional, or get rid of it entirely? I use my phone as a music player all the time and this is really frustrating
let it dry for couple of hours
