Hazel Update, pls help?
Not applicable
I have recently upgraded  form a 2GB micro SD card to a 8GB SDHC card for my Sony Ericsson Hazel  (J20i). Although the phone reads the data, it is not able to write  anything on it. Even save photos from camera. Pls help?
Also I have updated my phone software (first from on the Air and then using a PC).
My  pre-installed indian languages in the phone is completely gone and my  phone is not able to track GPS. Kindly let me know if sony ericsson will  be coming up with another update anytime soon?
15 REPLIES 15
higwayman
Visitor
upload a picture of the memory card you bought. Lets see which manufacturer it is?
A memory card shouldn't be affecting all those things you just describe, like the phone breakdown.
If inserting the card breaks the phone, then removing the card restore the phone.
Not applicable
Hi.. None of my friends have an 8 GB card for me to test it.
I have put a photo of the card that I have purchased.
Dr_Chris
Champion
Well if you can't test this memory card in another phone, I would suggest you get a refund for that one and buy a Sandisk 8GB micro sd from Amazon, where you can get a new one for under £10. Since the original memory card works fine with your phone and the new one doesn't, despite you having reformatted it, it's pretty clear that there's something wrong with it.
Not applicable
Well I guess I'll have to change the memory card and see.
The other thing is that with the new update, my Indian language support has gone. Is there any way I can get it back??
Now I get Chinese and Indonesian languages which are of no use to me.
Dr_Chris
Champion
That's strange, are you sure you have the right update for your country/region? Try re-running the update service and see if the Indian language comes back, otherwise contact SE support.
Not applicable
Hi Rishi, just wondering if you managed to find a solution to this problem. I had this exact same issue back in August and at the end left the card in the draw because it wasnt writing data correctly (my pictures would be corrupted or songs were missing) I think it may have something to do with the HC class (high capacity) of the memory card. Hopefully you are able to let me know what you have done to get around this problem.
