Emergency Calls Only
Not applicable
Please can anyone help?
I have a Vivaz phone and although it can receive calls and send/receive text messages, it often gives the message 'Emergency Calls Only' when trying to make a call.  This is not a SIM card issue as I have tried other SIMs in the handset but I get the same error.
There are various forums with people saying the same thing but there doesn't seem to be any answer to the problem.  In these forums, people on different networks have posted problems meaning it is not the network at fault either.
Thanks
2 REPLIES 2
Jeff
Enthusiast
Have you ever updated the software or had a technician look at the phone?
You can update at: http://www.sonyericsson.com/update
and you can find our contact information by country here: http://www.sonyericsson.com/cws/corporate/common/contact/phonelist
Since this has not effected all devices out there, it is obviously an isolated problem that can be resolved.
Let me know what happens!
Not applicable
Hi, Had this problem and I resolve the issue by doing the following
Click Menu
Click Settings#
click connectivity
Click network in use
     in operator selection click where it says automatice
Click Manual
The phone will search
Select Orange
Phone will request
Then you will get a message that says something about Home network selected... might not be exact.
This is obviously not the best option, but it resolves the problem, until it happens again.
I hope this helps.
Shannon
