Call disconnecting immediately
Not applicable
I have a strange problem with my Xperia X10....the call is getting disconnected immediately as soon as I dial the number
Also checked if its is an issue with the sim card but its giving problems to other sim cards also.
check all the call settings but of no use.
Can any body help in this regards please
10 REPLIES 10
KrazyD
Contributor
Have you tried using the repair option using SE PC Companion or updating the phone using Sony Ericsson Update Service?
Not applicable
No I have not tried... can you please let me know the steps on how to do the above activities...
I am a bit new to this.....
thanks for your prompt reply.
KrazyD
Contributor
Try the update service first its easiest. Download the program from here http://www.sonyericsson.com/cws/download/1/110/61/1283758423/Update_Service_Setup-2.10.9.13.exe and once setup select your phone model and follow the onscreen instructions as they are fairly straight forward.
Not applicable
I am doing the steps will let you know once its done....
Not applicable
I have done the above steps and updated the service but it didnt work mate....
Any other solution you know which could help me.
It would be very helpful
Not applicable
Does any one have any resolution on this.
Please let me know.
higwayman
Visitor
you are using  a SIM which only allows you to call a local number. If you are using  a prepaid card, check the pre-condional rule for the usage of the SIM.
Not applicable
Even if I call any local number or any international number its not working...
I have checked with both prepaid or postpaid sim then also its not working.
Any other suggestions will be really helpful.
I think it might be an issue with the phone...but dont know what issue is this.
Markus1
Leader
Hi sreejith.sreekumar1984,
I'm sorry to read about your issues.
If you have tried to run Update Service and also have tested your phone withother sim cards there's not that much more you can do on your own.
I suggest you contact your retailer to have your phone sent to a repair center.
