I try to listen to BBC Radio over the web (outside the UK) but get the mesage that the mobile is not supportet. Anyone that have a work around?
If it is the BBC Radio channels you are wishing to listen to, I would suggest trying an application called 'TuneIn Radio' from the Android Market which should allow you to stream this Radio channel to the handset.
Please be aware that you will require a full Internet connection available in order for this to work successfully. If possible, I would suggest connecting via Wi-Fi.
