Hi all i want to ask what does Backup do? thanks
Keeps a copy of you phone and memory card data on your PC.
But when you do backup in your phone what does it do?
backup in the file manager is a very gud option to backup all like msg,contacts,settings,etc.. in memory card and this backup option is use when u restore factory settings.. the saved backup settings ll be installed after a restart...
As i understand you save all your contacts messages and files of your phone to your phone card.Im I correct?
yep ur rite!!
