Applications
Not applicable
Applications
My phone says i need to download adobe flash player 9? in order to get some applications off sony ericsson.com.. how do i do this? then it says I have problems with java? All i want is to download some free apps from sony ericsson or anywhere.. any ideas anyone?
3 REPLIES 3
Not applicable
or does anyone know where i can download any apps for the phone?
Not applicable
Adobe Flash doesn't work on the X10, not until we get the 2.2 update
Not applicable
Do you have the market app on you phone.
If you do use that but you need to have a google email account which you set via your computer first.
Once you have the google email account you open the market app, the first time you use it, it will ask you to enter your google email account and password.
That's it, thousands of free apps.
If you dont have the market app try the web site below
http://www.getjar.com/
