x
XA2 Plus Wifi calling missing?
SOLVED
Stamatis1
Visitor
update to the Android (9.0) I didn't have wifi calling.
How do I switch WiFi Calling on?
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.PH.title
MarlonUk1
Expert
  • Connect your mobile to Wi-Fi.
  • Select the home screen, tap the Apps icon.
  • Tap Settings.
  • Tap More.
  • Tap Wi-Fi Calling.
  • Set the Wi-Fi Calling toggle switch to On.
5 REPLIES 5
MarlonUk1
Expert
is it supported by your network?
MarlonUk1
Expert
  • Tap Settings.
  • Tap More.
SaltySeadog
Visitor
I am on Vodafone and cannot see the option to turn on WiFi on my Xperia xa2 on android 9.
SaltySeadog
Visitor
  • Tap Settings.
  • Tap More.
I can go as far as the settings but there is no 'more' option.
profile.country.GB.title
WildCherryblossom
Explorer
Hello.
Did you manage to sort out wifi calling?im having the same problem.
Thanks
