El porcentaje de la bateria es incorrecto, comienza a disminuir en segundos. A veces marca 99% y a los segundos se apaga. La batería funciona correctamente
The battery percentage is incorrect, it begins to decrease in seconds. Sometimes it dials 99% and the seconds goes out. The battery is working properly.
gt
Hi @Channely, sorry to hear about this.
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
I would recommend that you recalibrate the battery in your device to start with. To do that, use the device until it has very little battery left (2-3%) > turn it off and charge it to 100% while the device is powered off. This usually takes around 4-5 hours depending on if you use a wall mounted charger or not.
Let me know if that helps!
@Channely wrote:
El porcentaje de la bateria es incorrecto, comienza a disminuir en segundos. A veces marca 99% y a los segundos se apaga. La batería funciona correctamenteThe battery percentage is incorrect, it begins to decrease in seconds. Sometimes it dials 99% and the seconds goes out. The battery is working properly.
gt
Hi @omar92, welcome to our forum!
Is there anything I can assist you with? I can see that you have only quoted a previous post!
