- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
May 2020
May 2020
sony xa2 ultra
при раздаче интернета по wi-fi ток зарядки ограничен смартфоном 0.4 ампера,
хотя зарядное устройство может выдавать ток 1.5 ампера
в результате батарея разряжается в ноль и смартфон отключается
вот какая у sony умная зарядка, при подключенной зарядке батарея разряжается в ноль
4 REPLIES 4
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2020
May 2020
hello @Rod_Stewart
when you are using the wifi hotspot. are you charging the device using the original charger and the wall mount adapter?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2020
May 2020
i'm charging the device using the original charger Sony UCH20
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2020
May 2020
ok. now can you try to boot your device to safe mode by long pressing the power off option. then use the wifi hotspot.
does it still drain as it was before?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
May 2020
May 2020
safe mode the problem is not solved
