While using Xperia XA1 Ultra it freezes suddenly and a drop box appears "Process System Isn't Responding" ๐
And if it is really frozen you can do a force stop.
The manual:
i have same problem ......:-(
Need help asap please. My phone alarm went off this morning and after I turned it off my phone has frozen showing this msg so can' open my phone which I need to use urgently.
Tnx for information...
Unplugged charger and phone has seized showing process system isn't respondig
*sigh* This keeps happening to me, too. I've deleted apps I wanted, photos, themes - anything I can think of - and completely stripped it down, twice... Still happens. In fact, it's much worse since the last update.
I used to have a similar problem with my old Xperia, too.
Why can't such a long standing, ubiquitous problem be solved?
Is it just Sony phones, does any end user know? Or do you know of an android it DOESN'T happen with?
I have the same problem, it's very annoying.
I can't find any solution to this problem.
Have the same problem
Where i can find the DROPBOX ?
Anyone found solution for this..?? please tell if any..
Naznaฤite sviฤanje na Facebooku
