While using Xperia XA1 Ultra it freezes suddenly and a drop box appears "Process System Isn't Responding" ๐
I have same problem's with you
how to fix it?
Re: Process System isn't responding
Don't Know. Will you tell me how to boot in safe mode?
1) stop DROPBOX running in background
2)disable background data for Dropbox
3)enable datasaver
4)restart n check
I can't do any of that. My phone is completely frozen . Should I do factory reset?
restart to SAFE MODE and flush data/cache
Naznaฤite sviฤanje na Facebooku
