After the most recent update I'm having trouble with this OMA client provisioning.
It started asking me to configure which I had to do about 20 times and reboot the phone to make it stop.
Now I'm stuck with a notification which just says OMA Client Provisioning all the time. I cannot clear it. I have notification dot and make sound both turned off. How on earth do I clear it?
First person who says do a factory reset gets a black eye. I've already done 2 factory resets on this phone in 6 months. I have a life to lead. The answer is to fix the bugs not factory reset every five minutes.
I will never have a Sony again after all the trouble I've had with connectivity. And everybody I know is going to know how useless this phone is.
Try the following:
1. Go to Settings -> Apps & notifications -> App info
2. Tap on the 3-dots icon on the top right corner then tap on "Show system"
3. Scroll down to "OMA Client Provisioning" and tap on it
4. Tap on "Force stop" and confirm, then tap on Storage and "Clear data"
5. Restart your phone
Try the following:
Thanks for your help Quester that worked first time.
Thanks, Qatrium - brilliant, worked first time!! 😀
