Sry Schailens but that Sounds stupid. I Do habe the Same Problem and waiting wont solve it. Its clearly an Software Problem. Phone Batterie is also Charging much faster After the last update. I also cant use the Phone while Charging cause it gets way to hot.
Its the top only. Front and backside is getting really hot. Also Battery drains faster even with the new Stamina mode always on. Maybe i should reset to factory defaults and prevent updates.
