Hi again!
I am sorry for my reply as well.
I'm glad to hear that you found a clipboard in the Swiftkey keyboard that you can use!
Thanks for sharing this and I'm happy to hear that you are enjoying your new Xperia phone.
Let me know if there is anything else and have a great weekend!
clip board? or you mean a flip case?> https://www.sonymobile.com/global-en/products/accessories/style-cover-flip-scr60/
you can ask your Local support for local availability and pricing
Hi @Vasso,
I'm afraid that it's not possible to view the items stored on the clipboard, you can however copy a piece of text and paste it into for example, a document in Google Keep.
To do that, double tap on the text and you will see a few different options, "Cut", "Copy" and share. Tap on "Copy" and find the place where you want the text to be displayed, press and hold on the an empty area > the same menu will appear, tap on "Paste".
You can also share all the text with a certain application, for example if you want to share it in a new conversation in the Messaging application and so forth.
Let me know if that helps!
Hi again!
I'm not quite sure what you mean, are you trying to copy a URL (website link) from the Chrome browser?
To do that you have to tap in the address field in the browser once, double tap on the URL and tap on "copy".
If you meant something else, could you elaborate a bit on what you are trying to do?
Keep me posted!
