Mon téléphone ne prends pas la charge en induction faut il un adaptateur ?
My phone does not take the charge induction does it need an adapter?
-GT
Hi @Dent2souris, welcome to our forum!
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
I'm not quite sure that I understand your question, or if you are experiencing any unexpected behaviour with your device, would it be possible for you to elaborate a bit?
You will need to use the USB cable that came with the device to charge it, either via a USB port, or with the wall mounted charger that was included in the box.
Keep me posted!
Hi.
I would like to know if it's possible to charge the Batterie of my XA1 Plus with an induction charger.
Thanks
Alexander
Hi @alexanderkyas,
You can not charge the Xperia XA1 Plus using QI charging, you will need to use a cable to charge the device.
Our devices that we have that supports QI charging is the Xperia Xperia XZ2, Xperia XZ2 Premium and the Xperia XZ3.
Thanks!!!
