When I turned the bluetooth on, this error keeps on poppin up "BLUETOOTH SHARE KEEPS STOPPING", When I close app, the error message shows up again and keeps on looping.
Attached is the screen shot of the error message.
My Android Version is 7.0 and Build is 33.3.A.1.97
Please kindly help me to solve this issue.
I have same problem on my X compact. I do restart and it doesn't appear for week or more and then again
Amazing!!! It did fix the problem of my xa ultra
Bluetooth is a nice technology but it is rather fragile.
Even my cars' entertainment system warns me that I have to re-establish the Bluetooth connctions after a software update of the smartphone.
There are several options.
1) Clear bluetooth cache:
Goto settings-> apps & notifications->see all apps-> tap 3 dots upper right corner-> show system-> scroll to bluetooth-> tap on bluetooth-> tap storage-> Clear Cache & clear data.
2) Reset network settings:
Goto settings -> System-> reset options->reset network setting
#2 is easier and cleans a lot.
Accept that bluetooth is fragile.
How did you fix it?
