Hi @ran76,
To change the alarm tone on your Xperia XA go to the Clock app, then press and hold on the alarm you want to change until you see Edit alarm. Press it then click Alarm sound then change it to the signal you want.
Let me know if this helps!
Great to hear that it is working for you now! I'm afraid there is no other way to change the ring tone of an already existing alarm.
Let me know if there is anything I can help you with.
