Hi everyone,
I have had my Xperia X for about 2 months now. The issue with it is that the WiFi reception on it is very weak. I have to me within 1 meter of the WiFi router for it to actually load anything when connected to WiFi.
Any further the reception drops to almost nothing and it struggles to load anything! My laptop and all the other phones we have are absolutely fine.
Any ideas?
Thank you.
Hi @matinzk, welcome to the community.
Do you experience the same issue when you connect to any other wifi networks?
Yes I do.
hi i have got very similar issues and i have put phone on safe mood like i was told by a sony adviser but still wi if keeps dropping off
Hi @manniee, welcome to the community.
Does this happen on other Wi-Fi connections too? If so, I recommend you run a software repair using Xperia Companion.
If it's only happening on your home connection, check the following router settings using a computer. If you are not sure how to change the settings, check the user guide of the router or contact your router manufacturer.
I'm having the same issue, this phone has proven to be nothing but a dissapointment
Same problem with my Xperia X
