Bought my Xperia X at the end of August this year. Brand new phone. It was fine for a few weeks but now has a habit of freezing when the phone completes its charge cycle. The led is always green and when I perform a soft reset the phone is at 100% charge. Doesn’t freeze during the day, only when plugged in using the original power adapter and lead.
I did delete some apps and games I wasn’t using and this did seem to settle things for a few days but it started again. I can’t charge it overnight anymore as my alarm won’t sound if I do as it freezes.
Has anyone else had this happen? I have not done a full reset yet as was hoping to avoid this if possible. I did use the Bluetooth transfer suggestion when I changed to this phone, had a Samsung S7 Edge before and did find a couple of Samsung apps on my phone bizarrely, which I have deleted.
Any advice appreciated.
Andy
Unfortunately yes, doesn’t matter if in normal or safe mode. Just tried again in safe mode and this is the result:
Green LED and Frozen - soft reset needed to make it work again.
Hi @Starnett, I am sorry to hear about this.
I recommend you try performing a software repair using Xperia Companion. This will re-install Android so if this issue is software related this should fix it.
I've tried doing this tonight but the xperia companion doesn't work. It keeps crashing during doing a backup. I decided not to bother backing up in the end but when doing the software repair it failed.
Luckily my phone still booted up after disconnecting it from the PC. I thought it had bricked my phone to begin with. Really not happy with this situation at all.
I am sorry to hear about that @Starnett
If you are unable to complete the software repair, then I recommend you contact your Local support team for further assistance.
Hi. I managed to do a factory reset last night on the device itself. It did not freeze last night so I will see how it goes and contact Sony if I have any more issues. Thanks for your advice.
Did you ever resolve this problem? My phone started doing this last week and I'd hate to do a factory reset if it wouldn't solve the issue.
I also have this problem with Xperia X.
It doesn't happen all the time, but when it does a soft reset is required to force a reststart.
Same syptoms - unresponsive after charging and then battery is at 100% after reset.
The recipe is clear, isn't it?
Try a software repair with Xperia Companion.
