Hello i have xperia X f5122 and i am having a probelm i dont remmeber if i dropped the phone somewhere but camera started having some problems a week ago , i noticed it in whatsapp first when i opened whatsapp camera the black screenn appeared and said camera can not be started and restart your phone,
i restarted and same then i applied a little pressure to the camera and it started workeing again
same in camera app after a week it go worse i had to apply hard pressure to the camera to ake it work so i can switch to front camera , pink lines also started to apppear when i applied the pressure
i opened the phone and check if this is connection issue but it was not
todt i opened the camera again and now its wrking fine when i apply the pressure the pink lines dont appear but i have to apply the prssure to make it work
focus works fine so is the flash
i dont know it its a damage camera or camera cable , o i need to replace it? or i can fix it myself??
