What I found is the Sony Xperia X digital output was fixed at 24/192khz no matter what the music files format was played when I connected to external DAC. Is there any way that I can fix the digital output to bit perfect ? Thanks 🙏🏼 I don't mind if it involves rooting my X bcos I only use it for music
Did you find an answer to your question on XDA?
Do you think XDA have the answer ?
It's the place where other distros reside, so the answer lies there.
(as long as you want to root and install another OS)
