Does your compact overheat in normal use? You could use it as a hand warmer in the winter.
Yes, after a year and a half, two problems came up rather suddenly. One, I would run out of power by dinner. Two, it would heat up. I assume the battery is worn out. Can it be replaced?
You might take a look at battery status to see if there is an app running in the background.
In general it is not a bad habit to reset the software once in a while.
You're device will perform better.
O, and don't put everything back in place, keep it lean and clean.
