Hi Community,
I've updated my X Compact to Android 7 before Christmas but, for now, I didn't receive any kind of suggestions from Xperia Tips; anyone know how?
Thanks!
Thanks @MichalH94!
Your answer is great. I hope someone of the Sony's support tem could answer me (and you) about this issue I experience with the Tips app. I hope soon as possible...
Thanks again!
After the ultimate system update, Xperia Tips app doesn't work.
Can someone of Sony's support give me an answer about or inform me if it a know issue?
Thanks.
Since I have bought my X Compact, I NEVER have received only one suggestion by Xperia Tips.
Is this considered a "smart" app???
I tried every way to resolve the issue as clean the cache, install the newer version, give two software repair but NOTHING!
What I found very worse is that no one of moderator in this forum have the courage to try understand this problem with me or asking about!
Very very disappointed, this is not the way to work!
Hi Roadrunny76,
Thank you so much for your answer!
I will try your suggestion, I will complete the 7 steps of Introduction to Xperia and I will see what happens. Then I return to report the result, for sure.
Again, thanks for your answer, very welcome! :smileysmileythumbsup:
