My Phone didnt charge, only way was to restart ut with cable connected.
I did a reset of The Phone. Charge problem is still there.
But now i cant use front camera...
The one that shows you your beautiful race works.
I dont get what wrong..
Problems can be manifold.
If it is just charging then check amor USB port.
Maybe it is defective.
Front camera is quite another thing.
Do some testing using the support app.
Try how everything is going in safe mode.
However the most straightforward option mostly is a software repair using Xperia companion.
Information can be obtained in the FAQ section of this forum which resides behind the information tile in the main menu.
Don't hesitate to come back later and ask more questions after you have tried some options.
Happy hunting!
